Hifonic hfi 12s
pitbullninja
Whatever you do decide to get DON'T go over the rms rating. Over powering them will not make em louder, you'll end up blowing your subs and you're out the money and you have no beats.
If you try them build a box to spec and be easy on the power and if you're looking for louder just upgrade later on.
I hear you but I was planning on get a certain amp for this build
they will be fine on the 1k.
Any specific box i need since I'm putting that much on them?
id just start with 2 cubes each and then build the box bigger/smaller based on how they do in that box. don't expect to get the box perfect the first time id be expecting to build atleast 4-6 boxes before you get one that performs really well. but just keep at it and you will get it down.
I know but I was told that if you were purposely going over the rms on these subs you would need a different box than if you were doing rms
yeah usually but your only overpowering them by 100 watts each with isnt much plus box rise will probably take care of that. what amp are you planing on getting?
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
I heard they were decent for the price. Box is everything.
i tried to tell him... but he won't believe me.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
2 D4s wired in Parallel comes out to 1ohm nominal load.
I do believe you.. I just thought you need a special box for it
just build the box to its specs if you can find them, and idk how good theyll do on the low end.
2x sundown audio sa 12's
Crescendo BC2000
kinetik 1800, 1400.
Rockford punch 5,25 component set
MB QUART ONYX 4.80
Mechman 270a alt
well in a sense this is true. usually if you're overpowering them you want to stick to the smaller recommended volume, but it's still a ported box. it doesn't need to be bandpass or t-line or anything special like that. i mean it can be, but it's really unnecessary.
More box builds
Do the specs get anywhere near 32hz?
Idk how those subs would do on the low notes, ive never heard them before, i almost bought some, but i went with a better woofer. They might do decent if you can get a box tuned low.
Crescendo BC2000
kinetik 1800, 1400.
MB QUART ONYX 4.80
Mechman 270a alt
  • Who's Online   0 Members, 0 Anonymous, 1040 Guests (See full list)
