The "Scrap Wood Sixth Order"
Autruche
I've never built a sixth order bandpass and have no experience with them, so I figured the best way to learn would be through experience. I just picked up a brand new circular saw and have had the itch to start building boxes. I didn't have much wood laying around so I just used up what was laying around (Brich ply, MDF, and, yes, Particleboard) as it's just an experimental box anyway. Anywho... Here's what followed.
Did up a design: 3 cubes rear, 4 cubes front, 33 sq in @25Hz for the LF port, 144 sq in @65Hz for the HF port
Onto the build
Started with the pieces cut out
For the sides and back I had to use 1/2 particle board cuz it's all that I had laying around. So I doubled it up with glue and screws.
Then I had to trim off the exess screws sticking through the other side.
Much better
Need Test Tones/Sine Waves? Click Here!
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Pioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE Audio
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Hit me up on Facebook, if you want
Then I cut out the sub hole in the baffle.
Then I cut out and assembled the HF port
And then the front piece for the box
Here's how the HF port and the Front go together
Then I cleaned up the HF port with the flush-cut and round-over bits in the router.
Then I put together the LF port. I was worried that with such small port area for the LF port that port noise would be an issue, so I decided flared openings would be the best bet. I first tried to kerf MDF but that didn't work for me, it just became brittle no matter what I did so I just used cardboard tubes for the flares.
Then I mapped out the layout on the bottom piece.
Then I pre-drilled everything and glued and screwed it all up.
Had to bust out the corner clamps for the sides. If you don't have some, get some. They are like having 4 more hands.
Got that all taken care of
My Saab 9000 build
Then I went to dry fit the top piece and ran into this issue. That should be at exactly 15
Solution?
Much better!
I then dry0fitted the face of the box on to keep everything strait while I took the top of to glue it up.
And this is why I don't buy cheap shit. No matter what you can't get this POS to not eat up belts.
Then it came time to glue and screw the face on.
Added some speaker terminals
Before round-over:
After:
Down the HF port
The Baffle
The LF port opening
Down the LF port
And that's all I got. I still have to drill out the mounting holes for the sub, but I let a friend borrow my MT so I have to wait for him to stop over again for that. Hopefully it sounds as good as it looks, going to be testing it out today with a 15 sitting in my house.
My Saab 9000 build
Looks good. I don't know how long those cardboard pieces will last though. Good practice for the real build.
2001 VW Passat Sportwagen
Alpine ICS-X7HD
DC Audio 5K
SSA 15" XCON
Tantric Sounds 6.5HD's, Sundound Audio SA-6.5CS
Incriminator Audio IA6.4
XS batteries, KnuKonceptz wirez, Second Skin
looking good ! not bad for scraps huh !
4 I.A. Warden 15s
8 I.A. 20.1s
2010 140.0-149.9 Bass Race Points Champ/Over all champ
2010 140.0-149.9 Bass Race S.C. Regional Champ
2010 FL Regional Middle Weight Champ
2010 INAC Middle Weight Bass Boxing Champ
Looks good. :)
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
AWESOME scrap wood box!! Thats an awesome box even if it wasnt scrap wood! Nice job!!! :clapping:
Follow my Tweet (Twitter)
Looks good, and no money really invested. Id like to see what this thing will do and how it sounds
2005 Lariat F-150
On 30 inch DUBS
6 Crossfire XS-V2 18's
2 Cactus 12k's, 1 Cactus 1000, 1 sundown 100.4
12 - 6.5 Crescendo mids and 4 Crescendo supertweets
SMD 340 alt, Mechman 270 alt
7 NSB 170 batterys
This looks great man! I've had the itch to try a 4th or 6th experiment for a while. Seeing this much go into just testing make me want to try it more. Be sure to post some texting results. Good work. :good:
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
  • Who's Online   1 Member, 0 Anonymous, 1125 Guests (See full list)
