Little update but not on the Expedition. A while back some neighborhood kids tried stealing the LED bar I had on the Camaro and ripped apart the plastic. Water got inside needless to say and started rusting and leaving nasty water on the paint. Went ahead and bought a new bar but this time I sprayed it with VHT nite shade to make it look close to stock and still have the same effect at night.
side by side
when trying to fit it back in it started to crack and flake off, first time using it so lesson learned.
after everything done and dried.
box looks good and creative place to put the amp!
I would fix that ground and find a better spot asap tho!!!
You want, wait YOU NEED metal on metal contact to properly give the amp the power it asks for!
Dont be surprised if the amp blows shortly due to the ground being sandwiched between the mdf and a washer. Also that the metal is thin you really want a solid surface, like a frame rail, grind the paint or rust off, then bolt it so the metal and ring terminal are making direct contact.
thanks, I will be setting it up better soon. just been busy with work to dig in there again. also thanks for the input! :drinks:
That sucks. Make the best of it and I hope time flies for you brother :good:
My name is AdamThis is my Civic Build.7" Samsung Tab 2Kenwood KDC-X896Clarion EQS746Sundown X-15DC 3.5k @2ohmHatersGonnaHate's 02 Civic UBLELD Bypass for Honda Civic/Accord/FitDon's Jeep Grand Cherokee Rebuild
N8ball2013 - i think you'd stick your dick in a blender if it told you it was 40 wtih two kids your age. lol
srp365 - If posting were picking up bitches, I'd be going home single tonight
looks like tony montana sneezed in your car.
lol I only threw a couple things of the camaro up since someone asked and senseless to start a whole thread just for it on a couple things I have done to it.
Very clean, nice build.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
