is the re audio box calculator accurate
.75x2 = 1.5
So the port height would be 19.5
Are you doing a side slot port?, if so remember to put "3" in the # common wall box. And add the woofer displacement, it will change tuning slightly.
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
ok this is what i'm up to now. and everything should be correct i hope Untitled-1.png
On torres' calc you have to put 3 common port walls for a slot port. Also, port area is off because you didn't account for wood thickness, so your port height on torres should be 1.5 inches.
1.5 inches tall? i thought it was the height of the box minus 1.25 inches because the wood is .75
Oh sh*t, my bad,19.5 inches(# nine gets jammed on my keyboard sometimes), like azatgoth said.
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
dbl post.
its all good bro i f$#%ed up the math anyway it was 1.50 instead of 1.25.
  • 10 months later...
  • Who's Online   0 Members, 0 Anonymous, 1508 Guests (See full list)
