is the re audio box calculator accurate
ok so i used the re audio box calculator to design my box and it seems like its different from the torres calculator. here is what i got from both calculators
RE Calculator
Torres Calculator
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
The RE Audio Calculator is off, And sucks. Torres is dead on. So whatever you get with torres is right. :drink40:
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
damn, well looks like i have more tweaking with torres to do
Torres is better and maybe it's just me but the RE one only gave me dimensions for L Ported enclosures.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
Re calc doesn't account for bracing displacement, woofer displacement amongst other things. It's not terrible but not as accurate. Tuning will be different. Stick with Torres.
  • pa-pa-platypus
  • sorry not everybody has a companies nuts so far down their throat they catch every drop ball sweat when it falls
its pretty accurate on the box area, but other than that yes the tuning is a few hz off, and it also seems like the port area is off.
I think there are like 10 threads about this on every forum I'm in. Stick to Torres
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
On torres' calc you have to put 3 common port walls for a slot port. Also, port area is off because you didn't account for wood thickness, so your port height on torres should be 1.5 inches.
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
Its not hard to be accurate on box area. Its simple math no calculator should be needed!!!!!
Its just Height X Width X Depth / 1728 = area of box.
1.5 inches tall? i thought it was the height of the box minus 1.25 inches because the wood is .75
  • Who's Online   0 Members, 0 Anonymous, 949 Guests (See full list)
