white4d96 Posted November 13, 2011 Report Share Posted November 13, 2011 I have my remote wire for my amps running through a kill switch on the dash. I hit it the other day when I saw a cop, and when I turned it back on, my mids and highs amp wouldn't turn on. Pulled the fuses, put them back, now power on/no output. Sub amp worked fine the whole time. Is the kill switch what caused the failure? Mids/highs amp is a Cadence F600-4, sub amp is a Massive N3. I tried swapping RCAs around to no avail. Ugh. Quote Too many projects, too little time... Link to comment Share on other sites More sharing options...
MrSkippyJ Posted November 13, 2011 Report Share Posted November 13, 2011 I doubt it, that is nothing different from turning your car off. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
BFF Larry Posted November 13, 2011 Report Share Posted November 13, 2011 Make sure the wires are still in contact with the switch Quote Team Clearly Louder (MECA)Team DC Audio ++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++ HMU!!! 3 flips. nollie flips. big flips. hardflips. - steez Youtube Channel My Build Log 95 Bonneville SSE - WALLED/4th Order - ~30 cubes - *thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931* Link to comment Share on other sites More sharing options...
sactownstang Posted November 13, 2011 Report Share Posted November 13, 2011 Get a dmm and find where is that remote power loses the 12 volts... Quote Link to comment Share on other sites More sharing options...
joemon Posted November 13, 2011 Report Share Posted November 13, 2011 I have that on my amps been doing it for year no problem Check ur switch Quote stevemeadedesigns.com/board/topic/105505-silvia-first-time-build-kenwood/ Link to comment Share on other sites More sharing options...
white4d96 Posted November 13, 2011 Author Report Share Posted November 13, 2011 The amp powers on now, but I get no output. Sub amp works fine. Quote Too many projects, too little time... Link to comment Share on other sites More sharing options...
mlstrass Posted November 13, 2011 Report Share Posted November 13, 2011 Can you hook an iPod directly to the amp to test it? Did you mess with any HU settings? I'm in Beach Park, so not far from you if you can't figure it out and want to stop by I could help you troubleshoot it Quote Link to comment Share on other sites More sharing options...
MrSkippyJ Posted November 13, 2011 Report Share Posted November 13, 2011 Check the input side first. First, make sure your speakers are still good and in working order. Then, get an ipod (or anything with a headphone jack) and plug that into the RCA inputs of your amp. If your amp works then it is no longer getting a signal. If it doesn't work, probably something wrong on the inside of you amp. Quote F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
white4d96 Posted November 13, 2011 Author Report Share Posted November 13, 2011 I swapped the 4-channel's RCA's to the sub amp and was able to get output to the subs so there's still signal going through. I think my amp crapped out. I'm going to try swapping another amp in to see if that one works. Quote Too many projects, too little time... Link to comment Share on other sites More sharing options...
mlstrass Posted November 13, 2011 Report Share Posted November 13, 2011 Do you get a power or protect light when you power it up? Quote Link to comment Share on other sites More sharing options...
