monkeyleg Posted November 15, 2011 Author Report Share Posted November 15, 2011 (edited) two Fi Q 18"s and a shit load of Polk MM6501 I could only fit a Mechman 200. Big 3. 2 positive and 1 negative runs. three Kinetik 1400. And planning on getting a DC 7.5k to run at 2 ohm, and most likely there will be some rise, so I'd like to be running at 4 ohm. Titebond or Guerilla Glue? Edited November 15, 2011 by monkeyleg Quote Google it Link to comment Share on other sites More sharing options...
BFF Larry Posted November 15, 2011 Report Share Posted November 15, 2011 two Fi Q 18"s and a shit load of Polk MM6501 I could only fit a Mechman 200. Big 3. 2 positive and 1 negative runs. three Kinetik 1400. And planning on getting a DC 7.5k to run at 2 ohm, and most likely there will be some rise, so I'd like to be running at 4 ohm. Titebond or Guerilla Glue? I've been using titebond for all my enclosures. But I think guerilla glue would be pretty good as well. Wouldn't running that much power to a set of Q's be a little scary? Quote Team Clearly Louder (MECA)Team DC Audio ++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++ HMU!!! 3 flips. nollie flips. big flips. hardflips. - steez Youtube Channel My Build Log 95 Bonneville SSE - WALLED/4th Order - ~30 cubes - *thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931* Link to comment Share on other sites More sharing options...
monkeyleg Posted November 15, 2011 Author Report Share Posted November 15, 2011 They should take around 1800 each, so around 3600 and the DC 7.5k does 4400 at 2 ohms. I can't run at 1 ohm. Quote Google it Link to comment Share on other sites More sharing options...
mlstrass Posted November 16, 2011 Report Share Posted November 16, 2011 don't waste your $$$ on gorilla glue, doesn't bond very well. Titebond II or Elmer's pro will work fine. Get your cuts close and use caulk to seal up the inside. Should be no need for FG and resin for your wall. Mids would be no different there then a panel over the wall. If you move enough air the sound from the mids might get distorted on some songs no matter where you put them. Quote Link to comment Share on other sites More sharing options...
monkeyleg Posted November 16, 2011 Author Report Share Posted November 16, 2011 Damn, I did a couple searches on comparing glues, and titebond won everytime! Guess I'm switching. Thank you. Quote Google it Link to comment Share on other sites More sharing options...
cjN Posted November 16, 2011 Report Share Posted November 16, 2011 I feel like your subs would man handle your mids if they were there. if the mids are in an enclosure within the enclosure i wouldnt think it'd harm the mids at all. Quote 2x sundown audio sa 12's Crescendo BC2000 kinetik 1800, 1400. Rockford punch 5,25 component set MB QUART ONYX 4.80 Mechman 270a alt Link to comment Share on other sites More sharing options...
Lbox88 Posted November 16, 2011 Report Share Posted November 16, 2011 So gorilla wood glue isn't as good? Damn I got a big ass bottle of it when I built my last boxes. Quote UBL | Build Log Link to comment Share on other sites More sharing options...
Guest Posted November 16, 2011 Report Share Posted November 16, 2011 titebond actually bonds the wood together. Gorilla glue just sticks them together. Also, the big 3 is 1 positive and two different negative runs. Never hurts to use 2 positive runs from alt to batt though Quote Link to comment Share on other sites More sharing options...
NorthsouthproductionsNC Posted November 16, 2011 Report Share Posted November 16, 2011 It never hurts and highly recommended Quote Link to comment Share on other sites More sharing options...
Lbox88 Posted November 16, 2011 Report Share Posted November 16, 2011 titebond actually bonds the wood together. Gorilla glue just sticks them together. Also, the big 3 is 1 positive and two different negative runs. Never hurts to use 2 positive runs from alt to batt though Gotcha. Learning something new every day. After doing it wrong of course lol. Quote UBL | Build Log Link to comment Share on other sites More sharing options...
