Worst install mistakes?
What is the absolute worst install mistake you've ever made?
I was doing the big three upgrade on my 'Yota and had to relocate the battery - post / chassis ground to the front section of the frame because the terminal on the end of the wire was too big to fit on the fender. I double checked everything to make sure when I drilled I wouldn't hit anything major like a wiring harness, hose, etc...
So I felt comfortable with my drilling location and started to run the bit, I had forgotten which bits I was using (won a $20 110pc bit-set from Sears for X-mas) and sure enough, I was using the cheap bits. The bit had heated up and drilled through, but I had stopped as soon as it went through and it warped, next thing I heard was HISSSSSSSSSSSSSSSSSS!!!!!!!!!!
Turns out the drillbit had beef with my A/C condenser, so he stabbed the b!tch.
*If you look directly below the terminal , you'll see a hole on the top right corner of the condenser
2001 Toyota Corolla CE:
4x Crescendo PWX6.5's
2x Crescendo FT1-SE's
1x DC Audio lvl 2 M1 8 (looking for more)
Slot port box 0.7ft^3 @ 31.77hz
Rockford Fosgate R750.1
1/0 Knu wiring all around
Looking for XS Power D1200
I drilled a hole in my gastank while building my false floor
2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
set my Jeep on fire while I was welding in the mount for my Kinetik..... Who would thought fresh sprayed great stuff was so flammable....lol
1999 Lincoln Town Car-(build underway)
- (2) SA15s, 4th order, DAT 2500.1, O2 mids n highs, 250a alt, HC 2400, Big 3....
1994 Pontiac T/A for speeding tickets.-
- Currently on jack stands, wanting to be a real race car
"Your local forecast, all the ladies in the metro area should expect to see 8 inches tonight" - The Todd
Decaf, on 01 November 2011 - 02:38 PM, said:
i provide the ammo for destruction, the trigger finger is connected to the volume knob tho
URBAN GORILLA AUDIO
i built a wall...
is that what you called it? :D
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
i built a wall...
now i call it the great failure
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
I had a friend with a cheap mindset... He bought his car for $400, spent $600 on the system and decided to use a conventional battery in his trunk to "save some money". I guess he never paid attention to the instructor in our auto class (took Automotive Electrical Systems 1 & 2 at North High School) when he said the batteries give off Hydrogen gas when charging/discharging unless you're running an AGM, which would be sealed. He hit a bump in the road on the way to school which ripped out the ground wire to his amp then sparked on the casing of the amp... I think you guys know the rest. Luckily there wasn't enough built up in the trunk to ignite the gas tank which was directly underneath the trunk.
installed a run of 0 gauge wired it up and didn't realize the battery terminal needed a fuse. so i spent a day trying every possible spot to ground to when i was only getting .7 volts.
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Letting iH8PunkRok help with my builds.
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
i got a eigth of an inch away from a gas tank once, thats about it so far...oh, and CA gluing my fingers together once
