I was woundering if it is safe and will not damage my new xs power d975 if I wire it with my stock truck battery that I have. My stock truck battery has 400+ more cranking amps then my xs power does
As long as resting voltage is close to the same.
And get both of the batts checked for good charging
And no dead cells
Edited by BFF Larry
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
A lot of people say.not to mix wet and dry/agm batts
But there are also many people that say it can't hurt
Edited by BFF Larry
HMU!!!
95 Bonneville SSE
Ok hopefully it doesn't damage it
i wouldnt worry.
HMU!!!
95 Bonneville SSE
it won't cause problems per say, but it won't necessarily allow your XS to perform to its full potential. the stock battery will drag the XS batt down some, to the same level as the stock battery more or less. imagine running a mile with your friend who can also run the mile in the same time as you, vs running a mile dragging a sleeping bag with your friend in it. lol poor analogy :shrug:
True.
You gotta check voltage separately and if its really far apart. New batt would be good.
An alt that puts out sufficient amps would also be a determining factor in charging.
HMU!!!
95 Bonneville SSE
