bracing and port corners
yes. they take up a small amount of volume and thusly make your tuning higher
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
does bracing inside the box with dowels and putting a 45 degree corner in you port affect the tuning of the box?
dowels do, but barely noticeable.
45 at the port wall does affect tuning.
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
I would like to know this also....How much does it affect with 45's at the port wall....what if I bend the port wall at a 45 also...will it still affect or no?
These are things you would have to test.
my port is 3.5" wide. and from the corner of the L to the corner of the box its 5". but with a 1"x1" 45 degree angle it makes it 4.25". will it affect it alot? its just a small corner
Ideally you would want to keep the port 3.5", even at the bend. Just cut a longer 45.
Edited by OrionStang
SMD Super Seller
My Feedback Thread
how so? port displacement is already taken out of the gross volume of the box, so adding a 45 in the port does not remove anything extra from the gross volume.
but isn't it still taking area away from the port thus changing tuning bc the port area would be different than when figured?
  • Who's Online   0 Members, 0 Anonymous, 1517 Guests (See full list)
