PSI is my last option
sooooooooo i found this motor for a pretty cheap price. looked promising
OPTI1233D is the model number
http://www.lanzar.com/itempage.asp?MODEL=OPTI1233D
dude said it had a 2 9/16" inside diameter coil but honestly idk for sure
so yeah. what companies can provide me with some good soft parts to make this motor useful. looking for just 2k rms
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Odd those are not 3". I ordered a bunch of D1 coils that are in that range 2.58" ID 2.73" OD. Coils that fit kicker L7 and Alpine R 15"
I have the coils in D1 and D0.9 1.8"ww and 2"ww
its considered a 3inch, but smaller then a 3inch
IMO they are not worth reconing unless you take apart the motor, and machine the top plate out to fit a larger coil.
The gap in them is extremely tight.
The stock coil is a 2layer aluminum flatwound, and dont take anything close to their rated rms power.
They are built really chincy.
that is exactly what i did not want to hear
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
They are closer to 3 inches then 2.5 inches, so they are called a 3inch coil...
A 3 inch coil is never 3 inches tho, it could be from 2.8 all the way up to 3.25 inches depending on sub, but still are considered 3 inch.
Dont get me wrong, the motor looks BEAST as hell, but like i said, the gap is so damn tight that they use a cheap 2 layer coil. I tried a few different coils I had laying around and non even came close to being small enough to fit.
Edited by Audiofanaticz
well shit. do i have to take it apart to machine it? because that is gonna be more trouble than this thing is worth lol
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
are you looking to buy a motor right now?
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
i already have this motor
so no
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
