What size alternator would I need?
I have a 1200 watt stero system, interior leds, halogens, and soon I will have exterior leds, HIDs, and a train horn on my truck. How many amps would I need at idle from an alternator to power all of this? I do have a XS d3400 under the hood, but my stock 136 amp alt isnt enough to power it all without my lights dimming and voltage droping.
Also does any one have any good brands they would recommend? I was looking into mike singer alts.
big 3 should have helped, if not get the 270a from mechman its like 165a at idle
Edited by Miguels
should be fine. re check all of your grounds man
It only goes down to about 12.4 volts when it drops, but with the stuff im planning to add you dont think I will need a bigger alt with more amps at idle? My alt now does 136 max amps.
A beefier ALt with more @idle amps will definately not hurt.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
You should be fine with a stock alt and a good battery with all 0 gauge and the big 3 maybe possibly get your alternator re wound.
--2004 Toyota 4runner
New Build Log
-2002 Acura Tl-S
Old Build Log
Team DC Audio
spl dust is an option you can get on the coils... it's great for extra 1000 watts of power
where can i get this spl dust and how much is it. is it hard to apply? lol
I don't get why everyone is suggesting keeping the stock alt or modding the stock alt when the OP wants to upgrade the alt. The big 3 can only do so much, it doesn't make an alt 10x as powerful. /rant
A mechman, singer alt, or dc power alt would do your rig justice. Anything with 100+ amps at idle should be sufficient and leave you room to upgrade things in the future. Just make your purchase based on what you want to spend.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
  • Who's Online   0 Members, 0 Anonymous, 1452 Guests (See full list)
