Setting a Line-Out Converter With a DD1
So I got my DD1, my car is in the shop, so I still can't set my system.
But I told a friend I could use it on his system, but the problem is, he has a stock stereo with a Line-Out converter to his bass amp. Is it possible to use the DD1 on this, or will I get false readings? How would I go about this. Sorry if this question has already been posted.
Any help is appreciated,
Thanks!
Edited by cccmaa
yes, but dont be surprised if you find distortion in the signal...some LOC's do that.
I will buy one and run some tests on my bench and make a video of what you might encounter. Which brand is it you use? thanks! :)
Follow my Tweet (Twitter)
I believe my friend is using this stinger model. Hopefully I get to try the DD1 on his car this week!
http://www.sonicelectronix.com/item_17012_Stinger-SGN13.html
And your right, I don't believe LOC's give out the best quality so that's why I had my doubt about the dd1 working on it. That's also why I tell most people to get an aftermarket stereo instead of using stock when they are trying to hook up an amp. The RCA output on the aftermarket provides better quality.
Do an audiocontrol hi lo unit( what I have, lc6i to be exact :D) there claim to fame is that normal coverters lose bass as volume goes up(bass bandit as they call it) but there units fix the problem so they say, think it might just be a bass boost but what do I know
I was kind of interested in this as well. No update?
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
  • 1 month later...
Audio Controls statement is true about most LOC's the lc6i is a pretty good piece of equipment I have compared the use of cheapy ones my shop sells and the audiocontrol lc6i's I have purchased to do side projects and there is a huge difference in sound but as for the Stinger LOC mentioned I used a few different Stinger LOC's and they are pretty good units compared to the usual ones my uses. I have one in my cousins car and one in my gf's car but I haven't put the DD-1 on either yet. I will take some time out and try it and post updates when I'm done.
2013 Dodge Charger
Build Log
1996 Ford Explorer XLT 5.0
Build Log
2005 Honda Civic LX Coupe
Build Log
SMD SUPER SELLER!!!!
My Selling Feedback
  • Who's Online   1 Member, 0 Anonymous, 1463 Guests (See full list)
