DC Sound Lab
i am seriously considering buying a dc xl 18 as soon as i can get the funds..
my question is how would having an extra spider affect the sub
and what is the recommended tuning at 6 cubic foot
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
why do you need an extra spider?
tunning can be whatever you want what kind of music do you lisen to?
the extra spider will raise the fs and make the sub stiffer you usally need more power to move more spiders
extra spider will stiffen suspension which reduces the chance of reaching mechanical limits (essentially it can take little more power depending on the spider pack you get). Tuning should (speculation because i havent used XLs) probably be 32-35hz with 110 sqin of port. (i have only used the 5s and 4s so ill let someone who uses the XL tell you what is concrete with them).
Edited by ChevyBoy95
the xl's are sold out right now, so i was looking at one thats up for sale and it had the extra spider option.
as for the tuning i figured something like 35hz or 32 hz if that would work
ive heard they are very musical and get LOOOOOOOOOW if in the right enclosure.
ah good i was already looking at tuning about there.
i want my xl 15 BACK!!! got jacked along with my aq 2200 :( XL'S FTW. i had great luck with mine tuned to 32. but if i had to do it again ide probly bump it up to 35. and it was very musical as previously stated.
BUILD LINK: http://www.stevemeadedesigns.com/board/topic/112034-2-sundown-18s-98-f-150/page__p__1565972__fromsearch__1#entry1565972
98 Ford F-150
Truck:
37" superswamper tsl radials
16" ion alloy wheels
3" body lift
2" suspension lift
Offbrand brushguard
PIAA driving lights
6000K HID's
System:
2 18" Sundown Nightshaed
Aq3500
Custom Fiberglass box
fosgate T1 6x8 Coxials
bass inferno 2000 watt 4 channel
2 XS power d3100's
0 Gauge
could they handle a little bit more rms with gains and all set correctly, my amp is supposed to do up to 1900 watts at 1 ohm
