POPLERO Posted November 30, 2011 Report Posted November 30, 2011 I've seen people wiring there sub(s) to bolts on the box. This is nice and conviniet when changing ohm load and such.. question I have is, what type of bolt is common to use here? Which bolts have the best conductivity? 2008 TBSS Black Granite Alpine CDA-117 Clarion EQS746 AudioQue Supertweets @ dash Alpine DDT-s30 @ b pillars Alpine SPR-60c @ front doors Alpine SPR-60 @ rear doors Alpine PDX-f4 Second Skin DampPro KNUkonceptz Wiring DCpower 270amp alt Optima YT underhood *temp Two15DCxls Hifonics bxi2610 *temp saz4500 and 4 xp3000s coming soon.
FordRanger Posted November 30, 2011 Report Posted November 30, 2011 I'm interested in this too, so I'll give you a nice bump. 2000 Ford Ranger XLT Ext Cab Pioneer AVH-P23000 Kicker 6x8s (2)Kicker CVX 15's (1) RE Audio XT4000DE V3 MonoBlock Amp Kicker 1/0 Gauge Wiring Kit
EclipseChris Posted November 30, 2011 Report Posted November 30, 2011 Home depot has brass bolts and nuts, but i just use regular 3" all thread rods. It really isn't a big enough deal to worry about it. Just be sure to have firm connections, i have seen loose connections short. i resolve to be a nicer moderator. Tercel build R.I.P. Eclipse build Old New V-Dub My feedback.
LoudBimmer Posted November 30, 2011 Report Posted November 30, 2011 Home depot has brass bolts and nuts, but i just use regular 3" all thread rods. It really isn't a big enough deal to worry about it. Just be sure to have firm connections, i have seen loose connections short. I had loose connection on negative terminal before so wire melted down.
G-Rad Posted November 30, 2011 Report Posted November 30, 2011 I'm guessing you'd be insulating the bolts from the actual wood with rubber liners, right? BASS MEKANIK RECORDS "Audio Implosion" & "SubSonic Guillotine" available anywhere digital music is sold! 2007 Ford Focus (NOTE: My cousin's build I helped him with) Pioneer H/U (4) Absolute Dome Tweeters on A & C pillars Scosche HD683A's in front doors Fosgate R168x2's in rear doors SoundQubed HDS312 in custom 2.57 Ft^3 @ 30Hz Audiopipe APCL-1800.1D Q-Mat Audio Technix 0 Gauge 119aH/850CCA Marine Deep Cycle batteries YouTube Channel: http://www.youtube.com/DWRhythm
POPLERO Posted November 30, 2011 Author Report Posted November 30, 2011 On my way to homedepot to see what I can find. I plan on having four 8gauge wires with soldered ends and a locking washer on the inside wall of the box (from woofer to box) and another set the same on the ouside (from box to amp) and curious as to if a rubber of some sort would be needed so wires don't touch wood? 2008 TBSS Black Granite Alpine CDA-117 Clarion EQS746 AudioQue Supertweets @ dash Alpine DDT-s30 @ b pillars Alpine SPR-60c @ front doors Alpine SPR-60 @ rear doors Alpine PDX-f4 Second Skin DampPro KNUkonceptz Wiring DCpower 270amp alt Optima YT underhood *temp Two15DCxls Hifonics bxi2610 *temp saz4500 and 4 xp3000s coming soon.
Namosh Posted November 30, 2011 Report Posted November 30, 2011 No need to insulate the bolts from the wood. Wood isn't conductive. My Ram Quad Cab Blow-through
6berry Posted November 30, 2011 Report Posted November 30, 2011 i would go with a zinc plated steel bolt since zinc is a better conductor than brass i believe. and wood isnt a conductor so no need to insulate anything 1999 Audi A4 1.8T::: 4 - DC Level 3 10's in a 4th order Rockford P6002 on Subs for now (3-3.5k coming eventually) MB Quart ONX4.60 for Mids and Highs Boston S50 Components in Front Boston S65 Coaxials in Rear 40 Sq Ft of Second Skin Damplifier Build Thread UBL 1948 Plymouth
POPLERO Posted November 30, 2011 Author Report Posted November 30, 2011 Ok thank you very much for the info.! zinc bolts it is.. 2008 TBSS Black Granite Alpine CDA-117 Clarion EQS746 AudioQue Supertweets @ dash Alpine DDT-s30 @ b pillars Alpine SPR-60c @ front doors Alpine SPR-60 @ rear doors Alpine PDX-f4 Second Skin DampPro KNUkonceptz Wiring DCpower 270amp alt Optima YT underhood *temp Two15DCxls Hifonics bxi2610 *temp saz4500 and 4 xp3000s coming soon.
