Sub problem
So i have an issue with one of my subs. When it hits some notes i will get a rattle sound from inside the box as if something us vibrating inside. I think it may be the plastic cover over the magnet but im not sure. Any other suggestions? If it is the plastic cover what would i be able to do to stop it from vibrating? Much thanks for support in advance.
possibly just the speaker wire
89 Chevy Caprice (is under construction)
dual alts
4/0 welding cable for wire
red top under hood 3 yellow tops behind the front seat ( who needs a back seat anyways lol)
big 3 of course
Eclipse 3000
interiors are getting rebuilt now
2 crescendo bc2000
2 shocker sig 12s
rebuild pics
I thought that was the case also but i have the same length speaker wire for both subs. The box has 2 15's each with its own chamber.
take it out and see if anything is loose
I did that also and could seem to see anything loose tried shaking it also, i do get a small rattle but its from the terminals. I dont think it could be those vibrating, but a possibility. I use 12ga speaker wire so they are nice and tight when the speaker wire is in.
What kind of sub is it cause my hifonics had some stupid plastic magnet cover that did the same thing I just pried it off at didnt hear it again
They are some cheap sound storm subs. CL15d
separate chambers? sealed box or ported? If its sealed it might be loose screws or poorly sealed, or could be the box is flexing and hitting against something under/beside/on top/etc..
Hammerdown... 1%
Yea separate chambers and its ported. I cant see it flexing to much i have around 500wrms to each sub, i used a dmm to see how much voltage the amps is putting and did the calculations. I have my H/U that has a sub gain set at -20 and the amps are zx1000.1 2011 model and the gain there is barely at the first hash mark. Once i get that dd-1 i will be setting everything properly. Just waiting to get the christmas shopping out the way.
  • Who's Online   1 Member, 0 Anonymous, 1409 Guests (See full list)
