The "1500" watts amplifier CHALLENGE!!!
fecupe2001
Couldn´t find any AQX to test with...
i would stick with what he tested, the tests are good.. only thing you'd have to worry about is how long it will last if you abuse it
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
Third at bat: Digital Designs M1b
Here you have some pictures comparing the M1b against the M2a :)
Input Sensitivity 8V - 0.2V
Variable High Pass Filter
Variable Low Pass Filter 20Hz - 200Hz @ 24dB/Oct
Variable Sub-sonic Filter 10Hz - 50Hz @ 24dB/Oct
Variable Bass Boost
Tested Voltage 12v -14v
Tested THD ≥1%
Damping Factor
Signal to Noise >100dB
Channels 1
Cont Power at 1 ohm 1150W x 1 @ 12v
Cont Power at 2 ohm
Cont Power at 4 ohm
Bridged
Dynamic Power 2500 x 1
Efficiency thru Output 80%
Dimensions - mm 350mm L x 175mm W x 51mm H
Dimensions - inches 13-3/8 L x 6-7/8 W x 2-1/8 H....15-1/8 L w/ mounting feet
Shipping Weight 11 lbs, 5 kg
Clamp results :
Voltage drop: 13.5v
50.6 Volts
49.3 Amps
49.1 x 45 = 2209 watts BOOM!!!!
49.1 / 45 = 1.08 ohms
Termlab score, sealed on the dash @ 42 hz :
I guess my box isn´t as efficient as i thought, my 1200 watts amplifier it´s actually a 2400 watts amplifier hahaha, i honestly doubted my clamp results so i re-did everything and had the exact same results, so you can imagine what´s about to happen now , testing the M2a :peepwall:
Fourth at bat: The mighty Digital Designs M2a
Variable High Pass Filter n/a
Variable Bass Boost
Tested THD ≥1%
Damping Factor
Channels 1
Cont Power at 1 ohm 1650W x 1 @ 12v
Cont Power at 2 ohm
Cont Power at 4 ohm
Bridged
Dynamic Power 3500 x 1
Dimensions - mm 500mm L x 175mm W x 51mm H
Dimensions - inches 19-3/4 L x 6-7/8 W x 2-1/8 H....21-1/8 L w/ mounting feet
Shipping Weight 15 pounds, 6.8 kg
Clamp results:
Voltage drop : 13.2v
52.1 volts
48.1 amps
52.1 x 48.1 = 2506 watts FUCK YEAH!!
52.1 / 48.1 = 1.08
Termlab score, sealed on the dash at 42 hz :
the numbers from the m1b dont match up. i calculated just under 2500rms off of ur numbers. was there a typo im guessing?
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
oh shit hahaha yeah sorry, i posted the correct numbers and calculations at the last but at the begging i posted the numbers from another amplifier i was testing that it´s not entering this test lol, just fiexed that, thanks for the input Bump4life :)
dang that sucks i wonder if its worth the more money the the normal ap line?
i don´t have a clue, if i find one i´ll surely tested it out and post it over here :)
BINGO , that´s exactly the point!!!!! I´m only testing watts and voltage drops, but i don´t know the amount of abuse those amplifiers can take, i´ve tested the brutus line A LOT and they surely can take it, but i don´t know much about the Audiopipe amplifiers, yes i´ve used a couple of them on friend´s cars with great success, but wired at 1 ohm on good electricals and those guys barely use their systems on the streets lol
You should put all of the numbers in the first post on the first page of this thread, and when you are done you could put it into an Excel sheet for organization. This is an awesome idea too. Im gonna be looking into a AP 1500 in the future :P
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
another great thread I'll be glued to :drink40:
hehe glad you are here Dave, you never got back to me about the 3518 , i have 3 already, looking for another one and build my wall next year :)
I´ll do that when i have more amplifiers tested lol, too bad it took me more than to start this test because of my voltage issuess, i guess i´ll continue with this thing next week :(
