Popping noise from speakers when brakes are applied
easy way to get by the infamous pioneer pico fuse
is to strip a piece of speaker wire wrap it around all the rcas on the radio..and either tie it into a screw on the radio or run that wire to a proper grounding location
every1 has thier own ways of doing things tho..im sure some1 on here will have something else to say
I have same issue as dylan. i have checked all connections other than the actual panasonic dvd player harness ground. Its been fine for 3 years and now it starts as a low alt whine then extremely loud at times and sometimes depends on weather. I donot want to buy new radio and still have same problems. anysuggestions ? i also plug my ipod directly into my audiop control xover to see if it was in trunk and it played fine. im guesin dvd player or rcas
thanks in advance
2007 Ford Ranger
(ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES)
K&N Performance Air Intake
Massive Audio D2400 Mono Amplifier
2 Custom Built 8" Subwoofers in Ported Enclosure
Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed)
4 - Pioneer TS-A6886R 6" X 8"
2 - SMD Heavy Duty Single ANL Fuse Blocks
2- Stinger SPP1200 Dry Cell Batteries
JL AUDIO Interconnects
2/0 Gauge Big 3
ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals
ILL Customz 1/0 to 4 Gauge Power / Ground Reducers
Factory Alternator
__________________________________________________________________________________________________________________________________
2002 Cheverlot Monte Carlo SS - (Deceased)
2 - Rockford Fosgate Power 1501BD
1 - Rockford Fosgate Power 851x
Rockford Fosgate Power 6 1/2 Components
Rockford Fosgate Power 3 way 6x9
2 - JL Audio W7 13.5" Subwoofers (Sealed)
Pioneer AVH-P4400BH In - Dash DVD Player
Pioneer AVIC - U250 - Add-on GPS Navigation System
Audio Control 6XS 4 Way Crossover / Line Driver
Ohio Generator 200 Amp Alternator
3 - Stinger SPP1200 Batteries
1 - Optima D34/78 Battery
More details...
Are the speakers powered by the HU or a separate amp?
From the previous comments, it sounds like speakers off of an amp.
If so, do you have an iPod/Discman/mp3/portable music player?
Try disconnecting the HU from the amp and connect the standalone portable player into the amp.
With the portable unit laying music into the amp, try the brakes again.
If its still popping then the amp is mostly to blame. If the pop goes away its most likely the HU.
Are the RCA's from the HU to the amp running by any power wires?
Can also try running a separate RCA cable from the HU to the amp that is held up in the air away from any noise sources.
:shrug:
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
  • 6 years later...
Having the same problem, BUT the problem doesn’t go away even with a pair of RCA’s connected to my phone, I can still hear that popping when I press the brake + alternator whine when revving...very frustrating.
Could it be the alternator diodes? ‘Cause the guy from where I got the amp told me that it doesn’t have any problem and I should try powering it on a friend’s car.
