Well... what are you powering with it?
x2
that would be key.
for all we know it could be a 300 rms amp, or a 5kwrms amp. :shrug:
also what should the fuse rating be? i have 150s being used. 0 gauge wire,
also 2/3 big 3 done. didnt to the alt run yet.. cuz my car's alt is in a horrible hard to reach spot.
you need that alt run then, and you'll be fine imo
What impedance are you running it at?
2x sundown audio sa 12's
Crescendo BC2000
kinetik 1800, 1400.
Rockford punch 5,25 component set
MB QUART ONYX 4.80
Mechman 270a alt
1ohm, yea when i go full tilt, ive seen voltages as bad of 10.9 while the song is hitting.. thats so bad,, resting it sits at like 13.7-14.9 after playing but after too much bumping i go way tooo far down that i cant even play the amp.. not to mention the amp's gain is at 25%. Im sure even if the gains were set properly it would be higher. AHHH this is the worst problem to have.
