the people who built my alt blame the low voltage and bad idle due to the 2nd wire to the alt (0 gauge) is this possible? or BS?
Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow
Bs... It's easy to just throw blame on something they dont know about, instead ogf just suckin it up and handeling business.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Low voltage because of better conductivity? LMAO, teach them a thing or two, then tell them to fix the shitty alt they sold you.
I was thinking the same thing, but they said only one wire can be on the alternator.
Who built the alt?
a local shop in baltimore. http://thebestbattery.com/
They are blaming it because of my alternator charging wire is too small (factory). It doesn't stay at 14.4V when RPM up, most is 14.4V Idle, i dont even want to talk about. this is what is pissing me off....
regardless if the OG charging wire is too small, the added 0 ga should help its cause regardless (still integrating fuse block and direct charge as well.)
One wire can only be on the alt = bs
They just dont want to own up and replace or fix your alt they fucked up..... Let them know you are no dummy and they owe you some money or a fixed alt.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
why would the diode be blowing?
Probably poorly made, if there is any sort of warranty on it I'd make them take it back and get something different.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
