Show them some pics of some of the builds here. Multiple alts and wires etc. Then, tell them to remove the alt, refund your money, and go to Mechman or DC, maybe Singer.
Lol this ftw...
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
One wire can only be on the alt = bs
They just dont want to own up and replace or fix your alt they fucked up..... Let them know you are no dummy and they owe you some money or a fixed alt.
This.
Let them know that you know what you're talking about. They think they're dealing with a customer with little knowledge and take advantage of it. Call them up and tell them whats wrong without asking questions and then TELL them what they are going to do to resolve the problem.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
I took it back. They basically blamed the 0 gauge wire for the blown diodes, and my charging system is bad through electrical. from my understanding, when the car is on, if the alt is proper, it should be 14.4-14.6 at idle, and at higher rpm. its not adding up...maybe the alt is just shit truthfully. it shouldn't be doing all this....blown diodes because of less current pull on a wire is crazy talk.
Pioneer AVH-p5700DVD | MB Quart Onyx ONX4.125 | 6.5 Alpine Type-S component & 6x9 3-way | Hifonics Brutus brz1700.1d | 2 - 12" Kicker L7 | Custom box tuned to 36 hz | 220A Mechman Alternator | 1/0 OFC Welding all the way back | Big 3 | 2 Farad Tsunami Cap | Deka 9a34 | 20% Tint | 6000K HIDs | Yellow Projector Fogs | Dual Out Magnaflow
Yeah they think they can play you or give you the run around, like DjCrush said TELL them How they will solve your problem and do not take no for an answer, they believe they have a noob on there hands and you might be but they dont know that. Just make sure the next time you talk to them let them know they cant play you sooo give you your money back and for them to take their shitty alt and shove it.lol
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
its rebuilt.....thats the problem. so technically, its mine for keeps. :shrug:
Did you keep the original regulator in it?
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
im sure they probably did...
That sucks man.... But just because it's rebuilt does'nt mean they dont owe you, it's not your fault they suckass if you would have known it was'nt going to work you would'nt have bought it you know? Soo I'd be whooping some ass if they said I was SOL for their shitty craftsmanship.B/c you would atleast have a working alt if it was'nt for them, correct?
And they should've upgraded the regulator also......
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
i guess this is what i get for a $150 rebuild job.........fuck me.
