BassMunky Posted December 11, 2011 Author Report Posted December 11, 2011 Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted December 11, 2011 Author Report Posted December 11, 2011 is my amp screwed? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted December 11, 2011 Author Report Posted December 11, 2011 can i still run my amp? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
Skullz Posted December 11, 2011 Report Posted December 11, 2011 Is it working? Did what happened only occur once or is it continuing? More information is needed to help you. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
BassMunky Posted December 12, 2011 Author Report Posted December 12, 2011 only once man and yest it working ok just i never play it at full tilt Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
Bmike Posted December 12, 2011 Report Posted December 12, 2011 you might want to find someone local to you with a oscope or dd-1 and see if there willing to set your stuff, flip them a twenty, never know until you try. atleast at that point youll know when your head unit distorts and your gains are set correctly. 2007 trailblazer lthead unit- pioneer p4300dvd crescendo ft-1 supertweeters pioneer m650 pros audiocontrol 2xs crossover Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas
BassMunky Posted December 12, 2011 Author Report Posted December 12, 2011 If the amp is capable of 8v pre-in than 1/2 gain would be close to where you would need to be so just adjust the gain to where you would think that the input voltage would match your 4v input. Now that will get you close but you may still soft clip due to being a tad bit over on the gain but better than way too much gain by just turning the knob and thinking your close. This still does not answer the question of the high pitch noise though, does it still do it or was it a one time thing. the high pitch noise from the amp and subs is gone Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted December 12, 2011 Author Report Posted December 12, 2011 If the amp is capable of 8v pre-in than 1/2 gain would be close to where you would need to be so just adjust the gain to where you would think that the input voltage would match your 4v input. Now that will get you close but you may still soft clip due to being a tad bit over on the gain but better than way too much gain by just turning the knob and thinking your close. This still does not answer the question of the high pitch noise though, does it still do it or was it a one time thing. i dont get where 8v pre-in when the deck is only 4v Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted December 12, 2011 Author Report Posted December 12, 2011 should i keep the my 1200 amp or get a sundown 3000k amp and run it at 2ohm, but i gotta get another battery right? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
BassMunky Posted December 14, 2011 Author Report Posted December 14, 2011 Is it working? Did what happened only occur once or is it continuing? More information is needed to help you. I turned the gains way down to 1/4 up. The high pitch noise coming throught the subs only happen after i was playing my system for a hour only half way on the deck. Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
