Bracing Help Box Guide idea
SlamminBeats
usually what i do is predrill everything and sorta of do a "moc up" then run a good bead of glue down and clamp everything together and run my screws in
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
screws while the glue is drying... run bead of glue..clamp wood back in place where it was when predrilling..then run screw in..thats how ive always done it never had problems
power: dd m4
i havent messed with bracing so far in my boxes just doubled up wood. but how would you calculate the displacement for them?
Oh this is simple...just get the volume from the height x width x depth...from the brace...just subtract it from the final volume. I do that when I have to work around wheel wells.
EX.
Let's say you use 1x1 for a brace....(which I do...because it's cheap =X) all I do is measure the distance...and for this example...18.5" long.... 1 x 1 x 18.5 = 0.011 ft3
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
  • Who's Online   1 Member, 0 Anonymous, 1420 Guests (See full list)
