noob question i know
i have 2 rockford fosgate t1d212's and i pulled them out of the box for the first time in 6 months and the coils are black. they sound good still no scratching they move freely and dont bottom out and they have never smelt burnt. they are in a ported box
also hooked to volt meter to check ohm and i am getting 3.5 ohm per sub when wired to 4 ohm
Edited by 01VWGREENMACHINE
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
hook a dmm up to the coils and see what it reads. the color of coils isnt too important for example i know dc dyes some of there coils different shades so they can tell the difference
when there blown they either scratch or are super stiff if you say they sound good then your subs are probably all right i dont know about the ohms thing though i know some subs read lower like my fi reads 1.7 ohms on each coil
getting 3.5 ohm per sub i subtracted the resistance of the wires themself
BIG 3
RF T400.4
all stinger wires
subs are always good until coil bits fall out like toast crumbs from the bottom of a toaster :D
Hammerdown... 1%
Does it look like paint? I've heard of some voice coils being painted to identify the ohms of the coil. But I think they were DC subs.
i wish i could get a pic ill try
BIG 3
RF T400.4
all stinger wires
if they are both 3.5 you should be fine there probaly dual 4 ohms woofers just my guess
i can switch between 1 and 4 ohm
BIG 3
RF T400.4
all stinger wires
