Bakerman Posted December 18, 2011 Report Posted December 18, 2011 Is it possible to have one master and 2 or more slaves? I'm running two BTL 18's on 4 AQ2200's, and I'm just curious if I can use one AQ as a master, and the other 3 as slaves, or is this only possible with one master and one slave? Quote
CJ18 Posted December 18, 2011 Report Posted December 18, 2011 No. You can have 1 master and 1 slave for 2 linked amps. I think rockford has the only amps that can be 2+ linked. Quote
mlstrass Posted December 18, 2011 Report Posted December 18, 2011 Run a master/slave for each sub, just split the input signal to the master amps. I run 6 3500's that way... Quote
tlee2 Posted December 18, 2011 Report Posted December 18, 2011 No. You can have 1 master and 1 slave for 2 linked amps. I think rockford has the only amps that can be 2+ linked. Yeah rockfords the only ones i can think of that you can run more then one slave Quote 6 Sundown X 15s 2 Sundown NS1 V2s C Pillar 4th order Bagged Suburban on 24s http://youtube.com/tlee333
Skullz Posted December 18, 2011 Report Posted December 18, 2011 Not quite sure if the bass knobs work with this but it may be an option. http://rwaudio.com/ld224m Quote 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
