i found these specs
(APOLLO SON OF BOLTAR)
Amplifier Type: 2-channel
RMS Power: 150W x 2 @ 14.4V
Bridged RMS Power: 450W x 1 @ 14.4V
THD at Rated RMS Power: 0.05%
Speaker Level Inputs: No
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: 0 or 12 dB
Frequency Response: 10-30,000 Hz
Channel Separation: >70 dB
Signal to Noise Ratio: >90 dB
Fuse Rating: 60 amps
O.o never heard of it, i must just be a :noob:
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Hmm... not sure on this one.
I know the series viii Boltars are still sought after and fetch $120 or so.
Have a question about Second Skin? E-Mail me!
Then if this is in good working order, I should pull the trigger? I think it'll be good on a couple of midrange drivers.
I think this particular model falls in right after the gen X models (the roman numeral ones), which was at the tail end them being made by/with Zed audio... but I could be wrong. It's been a while since I've looked into amps.
Nonetheless for $50, it should be a good buy (as long as it's in working order).
Edited by Second Skin Rep Jon
  • Who's Online   0 Members, 0 Anonymous, 839 Guests (See full list)
