How much does the cone of a fi 18" bl and 18" sp4 bounce up to?
Vooloco
The 15 will be lighter the 2 12s, but the 2 12s will be louder.
Your choice
Okay how much of a difference would it be between a 15" N215 and 2 12 BL's? How much louder is the 12s? Noticeably? Because the 15 N215 has the neo magnet so it is a lot lighter then the 2 12s with the traditional BL magnets. And I could probably angle the sub so it can aim at the back seats instead of to the roof because it is smaller then the 18 and mounting depth is over an inch less.
BASSHEADS UNITE
Technically yes
It is Slightly smaller yes, but the Xmax is they key
Say a 18 had 20mm xmax, but 2 12s had a xmax of 20mm each.
With similar cone areas, the 2 12s win because more air is moving, thus being louder.
you just contradicted yourself. if they both have the same xmax, which doesnt really matter anyways, yet the 18 has more cone area, the 18 will move more air. 20mm is 20mm. if you have two woofers it doesnt all of a sudden go up to 40, it stays at 20.
what you just said is like saying i have a 1000w stereo because my woofer is 500w and my amp is 500w. it doesnt work like that
How much power are you looking to run is the real question, and what do you have for electrical upgrades?
About 2000 RMS and i'm getting a 200 amp alt. getting 2 batteries in the back and the amp will probably be an audioque 2200D or the new crescendo 2000 ish amp.
1324421450[/url]' post='1808081']
Technically yes
1324421062[/url]' post='1808074']
1324420510[/url]' post='1808049']
Get 2 12s. It has more cone area then 1 18, so it will be louder (using same wattage).
1324420377[/url]' post='1808045']
I'm thinking about either 2 10s or 2 12s (fi bl's) How notifiable would the difference be between 2 10s and 2 12s?
Two 10" = 157.08
Two 12" = 226.19
One 18" = 254.47
ahem...2 12's does not have more cone area than 1 18.
Still no.OP, have you considered a dc xl? They are roughly equivalent to a btl and have a smaller mounting depth
no one can tell you how much louder it will be because its impossible.
I saw that coming. But thats not the case
Tell me then, what would move more air?
1 18 with 20mm Xmax, or 2 12s with 20mm xmax each
The 2 12s will be louder
Technically yes
BASSHEADS UNITE
Technically yes
LOLWTF.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
Well I mean can you notice the difference between 2 12s and 1 15? Or probably not?
1324421939[/url]' post='1808094']
1324421763[/url]' post='1808090']
Technically yes
The 18 - more volume displacement. Although the 12s have more motor force.
If it was me, i would just run 2 sa-12s on that amount of power. That amp doesnt draw much current, my bro ran his on a stock front bat, and a stinger 2150 with a 145 alt and his voltage stays above 13.5 gains set with dd-1. So a good front battery and decent rear will be all you need for that amp with that alt.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
  • Who's Online   0 Members, 0 Anonymous, 770 Guests (See full list)
