wmrcs Posted December 25, 2011 Report Posted December 25, 2011 Should I hook up my voltage meter at the battery or alternator? E34 540iT/6
Quiet Posted December 25, 2011 Report Posted December 25, 2011 at the amp 2007 Pacifica Rebuild. Less quiet. Still not loud.
Freshman6969 Posted December 25, 2011 Report Posted December 25, 2011 at the amp x2 Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog
matt14 Posted December 25, 2011 Report Posted December 25, 2011 Most will say your amp that way you know the exact voltage your amp is seeing. 2006 GMC YukonPioneer HU SHCA ran throughout Crescendo BC3500 One 18 AA Mayhem in a 4th order ZED Levithian 6 channel Rainbow Dual 6.5 comps ran Activehttp://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
MIKE-2U Posted December 25, 2011 Report Posted December 25, 2011 i have mine hooked directly to the distribution block that goes to my 2 amps. Hook it too what you want to monitor. the battery isnt the best plac because it is , well a battery. make sure to fuse the red wire with like a 15 amp fuse. 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
wmrcs Posted December 25, 2011 Author Report Posted December 25, 2011 Okay. So do I put the wire like where the power wire goes into the amp? E34 540iT/6
blownengine Posted December 25, 2011 Report Posted December 25, 2011 Okay. So do I put the wire like where the power wire goes into the amp? Exactly 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free)
OrionStang Posted December 25, 2011 Report Posted December 25, 2011 Yes SMD Super Seller My Feedback Thread
MIKE-2U Posted December 25, 2011 Report Posted December 25, 2011 yes NOT to the remote wire. 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
wmrcs Posted December 25, 2011 Author Report Posted December 25, 2011 Okay also these are the wires out of my volt meter. Obviously black is ground... and I'm assuming red is the one you hook up to what you want to be metered...what are the yellow and blue? E34 540iT/6
