Recommended amp
Dehubb
I have four db drive platinum series 15s (1000w rms) and im trying to pick an amp that will work my subs. Ive wasted lots of money and time buying amp after amp from blowing them. i will admit that they arent the best of choice, but they are what i can afford. I admit im a novice to installing, which i do not do, and to amp selection. I just want input on what kinds i should go for, new or old amps(i can try and locate discontinued amps) thanks in advance for the advice..
amps ive had
Planet Audio 5000.1 (burnt out) trash product will never buy a planet audio amp again.
Planet Audio 3200vx (burnt out)
DD 3000 amp (burnt out)
Power Acoustik ov1-5500 gothic series (damaged in wreck)best amp I had never burnt out, took some juice, have a friend with one on four 15 kicker cvx and he is king of the town with his.
Bc5500 is good for a budget.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
if you would save for a quality amp the first time and have proper electrical and wiring then you wouldnt be wasting more money buying crappy amps that are gunna die on you. go DD AQ DC Sundown. SOmething worth your time and money. Then never worry again, well lets hope
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
how much do you have to spend on an amp, figure that out. you know what you dont want thats a good start, and what do you have for an alt and wiring and are you willing to change these things if you have to . :drinks:
90 honda civic lx 4 door
sony cd head unit
mmats mp5 eq/crossover/line driver
35 farad hybred cap
ppi sedona 430ix on mids/highs
hifonics brutus brz1700.1d @2 ohm 1200w rms
front/jl audio evo 6.5 components
rear/kove audio 2 way 5.25
subs/pioneer premier tsw3002spl 12x2 1000wrms ea 3000w peak
and a hi amp alt 160a
http://www.stevemead...0s-honda-civic/
When you continue having problems, you HAVE to start looking at the constants...which would be you. I would almost bet that user error is the real issue with your equipment.
on a buget i recomend Hifonics or crunch ....hifonics hfi will not do rated and crunch rates peak so it will be a 500 rms amp if its a crunch 1000.1 etc....i have also been hearing good things a bout audio pipe
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
sounds like you better upgrade your electrical system before you keep investing in amps. Because either your voltage problem or ohm load is the problem
and my guess is your voltage
have you upgraded any of your electrical system???
also are you mounting the amp to the box or is it on the floor???
And what ohm load are you running your amps at???
Edited by 9515ROB
- 1998 Ford Mustang -
Time to rebuild.
4 15s and alot of power
TEAM DTF
  • Who's Online   1 Member, 0 Anonymous, 2071 Guests (See full list)
