Chassis to engine wire
Big three is where you upgrade the positive from bat to alt, and bat - to chassis, and chassis to engine. Someone was trying to tell me I didn't need to upgrade the chassis to engine wire as long as I always grounded to the chassis, and all I had to say was, "I read it on the internet". What purpose does upgrading this wire serve?
Basshead-in-Training
I believe it is engine to battery. That's what I did.
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
I agree with the poster above and I would say a circuit is only as strong as it's weakest link.
But I still dont get It, how does a ground to the engine help? You ground stuff to the chassis anyway.
Correct. Everything grounds to the frame/chassis. There is no need for a ground from the engine to the frame...there are huge bolts that ground the engine to the frame...thus making another wire from engine to frame basically useless (but not totally, like I said less resistance). Upgrade the engine ground to the battery, and then the frame to battery. Problem solved.
Edited by Rickdod3
Audio Technix Online Customer Service Specialist
[email protected]
Someone will correct me if I'm wrong but I believe the engine to bat is important cause that is essentially the ground for the alternator. The better the ground there, the better the charging system performs and the less chance of alternator whine caused from a ground loop.
ur right & you can never have to many grounds....... basic big there is alt to + bat - from alt or engine to batt.- batt to body & frame ....also it helps the alt give power with less resistance witch will make the alt last longe and your amps run cool and make more power
Edited by extremeauto
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
  • Who's Online   0 Members, 0 Anonymous, 797 Guests (See full list)
