Distortion with aftermarket h/u
http://www.crutchfield.com/S-EHin4IbpW15/p_120GMRC01/GM-Factory-Integration-Adapter.html
do you have an amp a factory amp i dont understand why you need rca outputs if you have no amp?
The GMOS came with the four RCA's for easy h/u installation. This way instead of attaching the speaker wires to the harness you plug them into the front and rear RCA outputs on the back of the radio. Well there are only the two preouts on the back of the radio for subs and front speakers which is why I cut the rear speaker RCAs and just tapped them into the harness
forget it take it somewhere to get it done. They gave you the wrong harness. and you butchered the harness trying ot make it work instead of getting the right one. I dont know of any harness for a head unit without a factory amp that plugs into your rca jacks. it just doesnt work that way. and Ive probably done about a dozen sunfires or cavaliers. Fuck I used to own one.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
