I have been out of car audio for lil over two years but plan on starting another build here soon.My first purchase is going to be my sub 2mrow and i am wanting to run it at 1 ohm.After being on the site again for a couple of days i have been reading on ohm rise due to the box and this and that.so my question is should i buy a dual 2 ohm and wire it down to 1ohm and hope for no rise or should i buy a dual 1 ohm wire it to .5 and expect rise? if more info is needed about the system just let me know.
2 15" DC LVL 5' crescendo 5500 yellow top under the hood and two xs power d3100
Big three upgrade
Rockford Fosgate T162S components in front
Rockford Fosgate T152 in the back
Dynamat everywhere
if ur gonna run 1 sub i would get the daul 2 run it 1 ohm u nore the amp should notice the rise...just my 2cents
although if u use a ton of wire it can affect the ohm load as well as the resistance
Edited by extremeauto
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
I am a believer of "Impedance Shift" not Impedance Rise.
Now, how you wire it more depends on the amp you are running and the electrical you have to back it. For example, at one point in the jeep we had it wired to approx. .35ohm but with x6 rise it was closer to 2ohm once the coils warmed up. The amps didn't have any problem as long as we warmed up the woofers for a song or two before really hitting it. Some amps will kick on and instantly go into shot circuit protect from your wiring. So yeah, depends on amp, charging system and how much rise you are going to get.
-Drew
uhoh_45 said:
this is another one of those threads where, if you have to ask about it, dont do it.
Agree'd
Its also one of those things that needs a, "go out and do it, and tell us how it went" response. Every car and every setup is different so there really is no straight response.
-Drew
well it will be on a AQ3500 with a dc power 270 alt and two xs power D3100
Big three upgrade
Dynamat everywhere
get the dual 2 wire it to 1 ohm and be happy and you wont have to worry about shit blowing on you
If you want more power after rise, buy a bigger amp..
YUP YUP!!!! this is what i do and why you will see crazy shit like 7k's and 12k's on a pair of mayhems or dc xl's i dont have to worry about ohm rise i got more power than i will every need on tap
