Overcoming cabin peak
ewall it off problem solved. you're working with one of the loudest vehicles on the planet ot wlal.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
or subs up port to the driver side.....
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Reg cab or ext cab?
All the detailsplease
ext cab
what all details would you like?
alpha damp on roof
hifonics hfi 2k
2 15" AB XFL
9 cubes 108 inches of port tuned to 34
currently box is subs up port passenger side (was port drivers side when i wrote this)
subs have not broken in
uhhh
what else do you need?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
7.5 after tuned to 36 with 90 sqin
Should help ya
Port up,
When firing sideways it adds to much pathlength
Great for numbers and lows but suffers the highbass
do you seriously believe those 6.5s will be able to make a clean transition at 45hz?
ive never met a 140 db front stage.
maybe i didn't make myself clear but he wants the higher notes to be strongest because 45-50hz hurts people more than 20-30hz does.
what we are going to try is subs forward port up. one sub on each side and port in the center. what tuning should i try?
I am just saying that the front stage is massively underpowered and judging the performance of a system setup like that is not the way to go regardless.
So I would recommend something like this:
6 cuft@38 Hz
And as before power properly the coaxes.
This is to go straight to 40-50, the suggestion by Ray above will be a more balanced approach.
Edited by Joe X
Subs up or forward?
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Up if you can fit it all, i usually do forward cause i dont have enohgh space
Will do
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
  • Who's Online   1 Member, 0 Anonymous, 2302 Guests (See full list)
