cal Posted December 30, 2011 Report Posted December 30, 2011 i have proven the theory that the voltage from the dash to the amp is off. if you want to monitor your amp go to the source hook up the voltage meter right of the amp negative positive ground and remote . what i did is hook up the volt meter to the amp and run wires to the dash or where ever you choose to mount the meter.i agree with the posts that the most accurate reading is from the amp because thast whats drawing most current .if its hooked up to just any 12 volt power supply the meter will work just fine it wont be telling you what is important tho.
MIKE-2U Posted December 30, 2011 Report Posted December 30, 2011 I had mine hooked to the battery.then switched to the amp. The battery barely changed the amp was more accurate. Mad Mike!!?? From that mtv pimp my ride bull S#%t!? 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
POPLERO Posted December 30, 2011 Report Posted December 30, 2011 My svmb is on my dash, I ran a long run from the amp in my rear (redwire) and connect groung (black) and remote (blue) up front.. 2008 TBSS Black Granite Alpine CDA-117 Clarion EQS746 AudioQue Supertweets @ dash Alpine DDT-s30 @ b pillars Alpine SPR-60c @ front doors Alpine SPR-60 @ rear doors Alpine PDX-f4 Second Skin DampPro KNUkonceptz Wiring DCpower 270amp alt Optima YT underhood *temp Two15DCxls Hifonics bxi2610 *temp saz4500 and 4 xp3000s coming soon.
Decaf Posted December 30, 2011 Report Posted December 30, 2011 red voltage sense wire should be on amp batt+... thats where the most amount of voltage drop occurs
SlamminBeats Posted December 30, 2011 Author Report Posted December 30, 2011 ok so i can either do all 3 wires to sub amp or red to B+, black to car ground, and blue to remote on the amp
SlamminBeats Posted December 30, 2011 Author Report Posted December 30, 2011 installed it sometime my voltae drops to 9 something on my amp
cal Posted December 31, 2011 Report Posted December 31, 2011 if your dropping to 9v you need to do some upgrdes to your electrical or kiss the amp goodbye.
Decaf Posted December 31, 2011 Report Posted December 31, 2011 u should not drop below 12.5v unless you are burping period. u will destroy your battery in no time like that... not to mention most amps wont even stay on during a drop like that. for burps most guys like to stay above 10.5v and thats with the car off. if you are dropping below that, you either have a terrible ground, clipping, too low ohm load or not enough electrical to back up the size amp you have
OrionStang Posted December 31, 2011 Report Posted December 31, 2011 OP, did you calibrate the meter by checking it against a dmm? SMD Super Seller My Feedback Thread
