Stinger Volt Meter Help
didnt calibrate it, and i suspect that to be part of the problem, amp never gets hot or anything, also my DD-1 should be here tm so my system will be set right. if it still drops it has to be the electrical, i did the ground perfectly, bare metal, 0 gauge.
Can someone link me to a good DMM for like 30 or less? if that doesnt exist then link me to one i should get
Well, you know these meters are adjustable and don't stay calibrated very well, right? It could be showing 9 volts when it is really 12-13. What voltage does it show, before it drops to 9? Like with the stereo turned down?
SMD Super Seller
My Feedback Thread
shows 14.1-ish, it has to be messed up cause it starts at 14.4 then somehow drops to like 14.1 w/o anything on, no heat nothing, i dont touch any electrical, and before i moved it, it never did that, im gonna have to calibrate it. I have no idea how to calibrate it tho =/
You can take off the display cover. Inside there is an adjustment screw.
SMD Super Seller
My Feedback Thread
as the alt gets warmer it slowly will produce lower voltage
my car starts at 14.8v cold and settles at 14.2v warm during the winter, 13.9v summer (stock 90a alt)
Decaf my alt does that too when its cold... Is that normal?
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
Yes, you will have better voltage on a cold start.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Go purchse a dmm if you don't have one already, very handy. Then monitor your idle voltage through the dmm... should be around 13.9-14.5v depends on if you have a HO alt. Then take the front faceplate of the stinger voltmeter off and dial it to the exact voltage the dmm says.
2005 VW GTI 1.8T
(4) Fi BTL N2 15s/ 4th order bandpass
(2) Crescendo BC5500s
Crescendo c1000.4
(4) Selenium 6w4p (Q logic Kicks)
Crescendo FT1 tweeters
3 runs of 4/0
Too much 1/0
DC power Engineering 320 XP ~235A at idle
3 XS D3100s
  • Who's Online   1 Member, 0 Anonymous, 2694 Guests (See full list)
