My mom has a craftsman garage door opener and recently one of the lasers was broken. Now you have to hold the button on the wall to get it to close. There has to be a simple way of disabling the laser, I tried jumpering a wire back and forth between the number 2 and number 3 screw but that didn't work. I've seen where people just point the lasers together like an inch apart but that wont work for me since the laser is shattered.
:trippy:
Edited by BassJunkie
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
Sure you could bypass it, it just may not be easy. All you have to do is give it the same signal it would get from the sensor. However, finding out what that signal is may or may not be easy depending on what it is, and then recreating that may or may not be easy. However, being a cheap thing as it is, I doubt it is anything too complex
its easy called discnect i worked n garage doors for years
What?
1986 C20 Suburban
B2 M1MKII
Maxwell Caps
Depends if its normally open or normally closed circuit
Either tie the together or disconnect
