6 inch ports would be easier and more effecient.. and as far as the volume it looks good but youre going to lose box volume when you add more port area
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
hum. the thing about 4" is that i found a site that sells them for 13 bucks and the 6" ports are 37 dollars and the other thing is should i use bracing? and if i should what should i use?
Edited by MrEwubbsZ
Anyone?
i have a ranger and ive done 2 15s in a street box. that equals NO LEG ROOM. lol the wall will definitely get you more legroom, but you will lose the rear window.hit me up if you want to know the different 15 boves ive tried in there.
Edited by poorboy6977
TEAM TRUTH HERTZ
DC LVL5 12
DD M1C
American Bass Mids/Highs
XS Power D3400 and D3100
Ohio Generator 270 alt
MECA Illinois Event Director
DC Audio Sales Rep
American Bass Distributor
Audio Technix Dealer
Incriminator Audio Dealer
If using 4" aeros consider this, port ends up:
Enclosure Specifications:
Fb = 33,2 Hz
Vb = 7,001 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 24 in
External Width = 48 in
External Depth = 15 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Front & Back (3 parts) = 48 x 24
Left & Right Sides = 12 3/4 x 22 1/2
Top & Bottom = 48 x 12 3/4
Port Quantity and Dimensions:
Number of Ports = 5
Aero Port Diameter = 4
Aero Port Length = 19
A double layer baffle is used which helps, additional bracing may be required.
The port length can't be 19 that is the sides od the box the more I think about it I don't think its possible to so this kinda ports in this box :(
Note that I am suggesting to install them in the top face of the box, is possible since you have 24 inches of height. You would place the subs on the front or back.
You have 46,5 inches wide , 5 ports 4 inches in diameter are 20 inches, 26,5 inches for the subwoofers, i think that properly placed everything can fit with some effort.. can't think of anything else anyways.
  • Who's Online   0 Members, 0 Anonymous, 847 Guests (See full list)
