to much port area?
t-money
Not sure. Never used it and have corrected designs for people from just about every popular calculator out there. Sometime the person enters the data wrong, sometimes the calculator is wrong. Most of the time the calculators are only wrong when a L port is involved.
Edit - as I see in this case, you did not add the # of ports
Always best to go back and check the design before you build.
Prety easy - If you have the calculator results:
1. Figure out the overall gross volume (L x W X H of the overall box using internal dimensions).
2. Determine the port volume displaced inside the box.
3. Subtract the port volume and the driver displacement from the gross volume to get the net volume.
Plug in the net volume and port size into something like this:
http://www.carstereo.com/help/Articles.cfm?id=31
Make sure the port length give by the calculator matches the required port length from the calculator above.
I took your box -
33.5 x 41.5 x 16.5 = 13.27 cuft gross
Looking at your ports, I assumed: 8.75 X 8.75 x 2.25 for the 2 outer ports and 8.75 x 9.5 x 2.25 for the center = .20 cuft
Just guess ~.25 for driver and bracing
Leaves ~12.8
Plugged that into the port length calculator until I found the ports needed to be 33" long, and at the length they are, you are tuned to 65 Hz.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
the yellow area accounts for the 2 ports that are using 2 common port walls
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
that only accounts for one port your box has 3
i know that. thats what the .54 in the bracing area is. the displacement of the other 2 ports
You realize air goes through those other two ports. They're not just taking up space in the box.
yes but if all the ports are the same size and length it takes up room in the box, so that changes your tuning a little but it also gives you more port area right
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
This is what it should be...(Except less bracing probably)
^ this
12- DC Audio m2Lvl3 12's1- Hertz HSK3 way2- DC5K's2- ZX350.42- Stinger SP1500D batteries in rear3- runs of 1/0ga. to the rearTeam DC Audiodc-banner.jpgdcsoundlab.com
Quality is all in how you take pictures ;) I have plenty of projects that look WAY better on camera then in person :D
crazy to fit so many in so little. Reminds me of some of the porns I've seen?
it changes your tuning by a bunch
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
ok.... it is 3 ports, meaning 3 8in by 8in holes that are 3in deep (or 8x8x3). So to calculate tuning, it is 8in tall, and 24in wide (or 8in times 3 because there is 3 ports), and 3in deep. Put it in and you get a shitty tuning.
ok well how would you tune it low. like 30 to 32 range. say u can replace the entire port wall
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
Can someone tell me how the calculator got the port volume? It says .30 cuft. An 8x8 port 3" long (2.25 internal which I see it knows) would be 9.5 x 8.75 x 2.25 = .108 cuft.
It throws off the net volume a little. Not a lot in this case, but like I said above I have seen several times where it gets off pretty good on L ports.
Current system:
Previous systems:
  • Who's Online   0 Members, 0 Anonymous, 1120 Guests (See full list)
