VVX-12 stopped working
Even if the dmm is set at 2000, I would think it would read close to 2, you know, rounding up.
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
its a D2 with another set of leads on the other side as well. Both read the same..Nothing at all
d2 sub reading 1 on the dmm...
to me this means its wired in parallel which will make it 1 ohm....
probly have a broken tinsel somewhere
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
3.5 cu ft for a single 12 on over its rms is wayyy too big imo.
even after displacements i figure your box is at MINIMUM 2.25 cu ft net.
the box you have i would say is only good for 4-650w rms, anything over that and your probably hurting the sub.
again, this is just my opinion, but its something that maybe you should look into.
big box = low watts
smaller box = higher watts
(source, many members from here in their build logs, etc etc..)
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
well regardless what the meter says, if you hook positive from the amp to the positive on the sub, negative on the amp, negative on the sub and you get no sound its a sub issue.
especially when you hook another sub up to the amp, turn it on and it plays.
skar does sell recone kits i do believe, theres not a sticky on it so you'll have to ask kevin or malib00m
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
ya i am working to get it all resolved with kevin. ill take it to a audio shop an see what they find out
Recones are $45 if anyone is curious.
could it be possible to add this information into the "SKAR VVX Subwoofer Series (8" 10" 12" & 15" Models)" sticky?
or is that a no-no.
and yes, i was actually curious because i own two VVX 12"s and eventually i'll have to do this :P
so thanks for that info :]
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
Is that a D1, D2, or D4 sub? What is other coil reading? Or is that just a single 1ohm sub??????? More info, as Ive never seen a single 1ohm VC sub
That 1 stands for infinite, which means there is no closed circuit.
it might help if your dmm wasnt set for AC voltage
maybe its set in the ohm area and you cant see it.....
if it was in the AC voltage it probly would read 0
No it wouldn't, have you used a DMM before?
It reads that way when the value is infinite.
set for 200, more accurate reading..but im guessing your tinsels are smoked somewhere
It won't read more accurate if it's a infinite value , only if the value is below 2ohm.
No it's not it's rading infinite, have you used a DMM before?
Thats what I was thinking....
Thinking wrong..(read above ;) )
again,have you even used a DMM before?
It doesn't round up to 1 IF that was the value it was showing. It's showing a infinite value.
  • Who's Online   0 Members, 0 Anonymous, 482 Guests (See full list)
