i donno how that would work with the port turning at the last second right into the sub you might get some cancellation
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
Yeah I think that's not a horn either. Actually I would be curious to know what discerns a T-Line from a horn enclosure. Hmmm
2002 Chevrolet Camaro 35th Anniv. Edition
Head Unit- Kenwood KDC-X794
Front Stage- Digital Designs DDAW6.5 Mids & DDAT28 Tweets
Rear Stage- Kicker KS650 6.5" Coaxial
Sub Stage- Sundown Audio SA-15 D2
Mids & Highs Amp- Sundown Audio SAX-100.4D
Sub Amp- Audioque AQ-1200D
Equalizer- Arc Audio XEQ 5 band graphic EQ 1/2 DIN
Electrical- XS Power D3400, Big 3 Knukonceptz 1/0g, Stinger volt meter & Knu accessories
Misc.- Over 80 ft.2 Second Skin Damp Pro, Overkill & Lux Liner
according to my calc..if it is a quarterwave tline.... ur tuned to 13.3333~ hz... thats really low....
unless thast the FS of your sub... OR... if this is for HT setup... i wouldnt tune that low...
if u are gona build that box fix ur corners by puting 45s in there..
info on quaterwave tlines here
http://www.stevemeadedesigns.com/board/topic/1828-quarter-wave-t-line-tutorial-updated/
Edit: tlines take up a alota room... im using a tline in my truck... tuned to 40 hz... low end is a bit lacking for me.. i would tune to 30.. but be carefull cuz there is no back pressure in a tline box... you could easliy destroy teh sub...
from experience.. i would rather build a regular box... i will only use a tline for anything below 800w rms...
Edited by spl4life
My first truck... My first Real build...
*Update 8/9/10 DC Power 270xp Alt is In!!!*
1997 Toyota T-100 DC Level 5 18" in a T-line
Everybody wants their system to be....
1. Cheap
2. Reliable
3. Loud
...you can only pick two.
micahmye hertz pack
you might want to calibrate that calculator of yours...
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
