clamping my aq2200d
MIKE-2U
so i decided to watch Brian's (Audiofanaticz) video . If i followed it correctly this is what i got
30 Hz Test Tone.
DDM - 40.00 AC Voltage
Clamp Meter - 11.16 amps
X
= 446.4
x 4 ohms
SUPPOSE TO BE 1,785.6 Watts RMS !!!?? is this right? out of a AQ 2200D !!??
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
definetly doesnt sound right. i don't think you multiply by 4 ohms. i believe your amps times AC voltage is your RMS. Thus you got 446.4rms @ 4 ohms. if that amp was doing 1700+ at 4 ohms it would have been know by now ahha.
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
AC voltage from the speaker outputs divided by the amp draw on the positive wire from the amp.
That will give you your impedance at each frequency.
Multiply the AC voltage by its self then divide that number by the ohm loads you just came up with.thats a heck of alot more realistic than just use 4 ohms or 2 ohms becuase you just did the work to find out what your amp is really seeing. so the wattages you come up with are alot more realistic.
All info can be found here http://www.stevemead...an-amplifier/ so with your numbers you had a 3.57 reactive ohm load putting out 448.2 watts. On AQ website for the 2200
4 ohm power @ 12V @ 1% THD500x 1
So yes it is doing rated.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
No my ohm load is 2 ohm. My sub is a d4ohn
So i clamp positive speaker wire or amp power wire? well the audiofanaticz video is wrong? brian we need you in here!
How do i lower the impedance rise?
Becausr my amp saw 3.57 ohms but is wired too 2 ohms hoe can i grt closer to my suggested amp load
2 more DVC 10's? :lol:
smaller box bigger port i believe.. dont quote me on this though
its enclosure based i know that much
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
  • Who's Online   0 Members, 0 Anonymous, 569 Guests (See full list)
