MIKE-2U Posted January 12, 2012 Author Report Posted January 12, 2012 My setup this week will change to 2 sa 10s at 1 ohm 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
ellowmoto Posted January 12, 2012 Report Posted January 12, 2012 so i decided to watch Brian's (Audiofanaticz) video . If i followed it correctly this is what i got 30 Hz Test Tone. DDM - 40.00 AC Voltage Clamp Meter - 11.16 amps X ----------- = 446.4 x 4 ohms ------------ SUPPOSE TO BE 1,785.6 Watts RMS !!!?? is this right? out of a AQ 2200D !!?? if only the aq did that at 4 ohms something with your calculations is definitely wrong
fecupe2001 Posted January 12, 2012 Report Posted January 12, 2012 What was your voltage droppping to?? I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
MIKE-2U Posted January 12, 2012 Author Report Posted January 12, 2012 What was your voltage droppping to?? i used a 30 hx test tone off youtube for 35 seconds and i believe the lowest voltage was 13.0 volts. I had an sa 10 dual 4 ohm wirerd to an audioque 2200d @ 2 ohms . now i buoilt a box for 2 sa 10s so i will retest with another tone and see what i get if it warms up a bit. 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
Robert8252 Posted January 12, 2012 Report Posted January 12, 2012 You're not competing you really shouldnt worry about this stuff. If it sounds good and you like it live with it. If you want it louder by bigger or more subs. If you want more power in the current setup spend the money on a rockford or a JL amp that has a "constant power" type output. My brother with two 12s and a aq2200 in a blowthrough was only getting 350watts from his rising to almost 7-8 ohms. He was still doing a 149.7. 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
CleanSierra Posted January 12, 2012 Report Posted January 12, 2012 At 30 Hz your amp might not pull its max power rating. To push a sub at a slow 30Hz doesn't necessarily require TONS of power. Put that test tone up at 45-55 Hz and I'll just about guarantee that power goes up. It takes alot more energy to move that sub faster than it does slowly I'd think. Im not the one you want to try to troll. Just a fyi for you.
kirill007 Posted January 13, 2012 Report Posted January 13, 2012 At 30 Hz your amp might not pull its max power rating. To push a sub at a slow 30Hz doesn't necessarily require TONS of power. Put that test tone up at 45-55 Hz and I'll just about guarantee that power goes up. It takes alot more energy to move that sub faster than it does slowly I'd think. Seriously? :facepalm: 450 watts at 13v and 3.57 ohms is decent, it's rated power. Thinking is the root of all problems... You ALWAYS get what you pay for.
