DC Sound Lab
As title says thats what im after. ? is how many d1600s do you think i will need to keep the voltage up and solid. have a mike singer 350amp alt.
hopeing cj can chime in and give his 2cents and any others that has run 16v system before. thanks
I have not played with that battery but can say im the astro van i have 2 kinetik 16volt batteries per 5.0 and a 400 amp mechman. The 5.0s are at.7 each and my voltage drops to low 15s when hammering on it
DC AUDIO
Phone Number
1(855)SPL-DBZZ
Built by Competitors, for Competitors.
I will have 3 XSPower batts per 5.0, but they will be running @ .35 when I finally get this thing done here soon.....240a Mechman here
'94 Ford Ranger Ext. Cab
(3) DC XL 15's, check that (3) 18's this year!
(2) DC 5k's
(6) XS Power D1600's
158.9.......so far......
Montana DC Dealer/State Rep.
right now, it's in pieces.....gonna try n rebuild box for 3 18's, if the box fits--will recone my XL's to 18's. Last year, I ran 2 12v "cat" batteries and stock alternator and did a best of 157.5. First burp without changing a thing but 16v batts...no alt yet and did 158.9. The amps are/were at .7 strapped so each will see .35 before box rise...hope that helps answer your ??
(2) DC 5k's
I am going to recommend 5 1600s. When I first installed my 7.5k, I had 5 d1400s and one singer 350. I had drop from 16.8 to 15.1 full tilt. Running 16v, you should be looking at similar power as I was with the 7.5.
  • Who's Online   0 Members, 0 Anonymous, 5403 Guests (See full list)
