Where does this go??
I have searched, taken off the air cleaner, and looked all over and cant find where it goes.
1995 Chevrolet truck
goes down under and i cant see where after.
I think it was for a block heater
Im not sure what you mean by checking the air filter but sometimes there is a plug like that on the ribbed part of your intake lines for the engine. Its a small o2 sensor that will detect how much airflow is being taken into the engine so that it can get a good air/fuel mix. If that is whats loose your engine will start but stall out after a few seconds of running the engine. If the engine will run just fine without any shudder then your intake is hooked up right. The only other thing i can think of for something that small on that engine it could be the block warmer like Ray said or maybe a sensor on the a/c to regulate the pressure and monitor it.
Ambient air temp is built into the maf on that truck
I say if it runs and no cel then fukk ettt
nvm guys, i found it. the truck i have has a light under the hood that can be pulled around under the hood (has a 6ft wire on it) and a casing where it winds into.
  • Who's Online   1 Member, 0 Anonymous, 1838 Guests (See full list)
