pa-pa-platypus Posted January 18, 2012 Report Posted January 18, 2012 3 subs in the same chamber with a common port would prolly be a good option... This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
dolarbilz Posted January 18, 2012 Report Posted January 18, 2012 3 subs in the same chamber with a common port would prolly be a good option... ^this And leave room for bigger ported box cause less port walls.. Any pics of box? Do you have exact demension of box.maybe somebody can help u out.
ehckz Posted January 18, 2012 Author Report Posted January 18, 2012 3 subs in the same chamber with a common port would prolly be a good option... ^this And leave room for bigger ported box cause less port walls.. Any pics of box? Do you have exact demension of box.maybe somebody can help u out. basic pics........box is 39" wide 13.5" tall and 24" deep.....nothing taller or wider is an option considering it took a grinder and hammer to make some "adjustments" to get the box in. Build In Progress for Slamology 2013 3 m1xl 18s walled in a gti 1 5k 4 batts audio technix 1/0 8 cheap r/f 6.5s mb quart 4.60
ehckz Posted January 18, 2012 Author Report Posted January 18, 2012 those pics were way before it went in, it was sealed and carpeted.....screwed and wood glued. Build In Progress for Slamology 2013 3 m1xl 18s walled in a gti 1 5k 4 batts audio technix 1/0 8 cheap r/f 6.5s mb quart 4.60
pa-pa-platypus Posted January 18, 2012 Report Posted January 18, 2012 so the subs are firing up? im guessing and what size are those ports? This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
Kobieblu Posted January 18, 2012 Report Posted January 18, 2012 Haha I went from 2 dual 12s on a 600 xplod to 2 t1s and t1k ....does that count ....then again I went from 139.8 to 143.7 RF love
ehckz Posted January 18, 2012 Author Report Posted January 18, 2012 so the subs are firing up? im guessing and what size are those ports? Yeah subs are firing up and ports are toward the cabin (into the backseat) I also removed the 6x9s because the subs beat them to death basically. Looks like this in car Build In Progress for Slamology 2013 3 m1xl 18s walled in a gti 1 5k 4 batts audio technix 1/0 8 cheap r/f 6.5s mb quart 4.60
412 CVX Posted January 18, 2012 Report Posted January 18, 2012 from those pictures it looks like you have a single 3 or 4 inch port per chamber, which isn't enough. if you build a new box with one big chamber and one big port, you would probably gain a considerable amount. what's the internal volume of each chamber after all displacements? Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
ehckz Posted January 18, 2012 Author Report Posted January 18, 2012 from those pictures it looks like you have a single 3 or 4 inch port per chamber, which isn't enough. if you build a new box with one big chamber and one big port, you would probably gain a considerable amount. what's the internal volume of each chamber after all displacements? Ports are 41/2 by 14ish and its about 1.8-1.9 per chamber.. Build In Progress for Slamology 2013 3 m1xl 18s walled in a gti 1 5k 4 batts audio technix 1/0 8 cheap r/f 6.5s mb quart 4.60
pa-pa-platypus Posted January 18, 2012 Report Posted January 18, 2012 from the looks of it you may be better off with just 2 in a good slot ported box..i dont know enough about ur vehicle to say that for certain but youd be able to give your subs enough port and make an overall better box..just my opinion tho This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
