best wood to use
bdog
im building a box where every MM counts so my question is Is there a wood thats stronger than mdf so i can shave down the wood thickness a bit?
REP
A lot of people use birch ply...but to be honest its same thickness as mdf...3/4"
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
Why would the same thickness matter, it's not the same material :pardon:
TDH FTW !!!
i think what he is trying to say is that space is an issue for his build so he wants to use a thinner wood to save space.
dont do it, 3/4" no matter the wood is the lowest you should go.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Yeah I was saying 3/4" is what everybody uses regardless of mdf or birch
Alpine CDE-hd148bt
Alpine PKG-RSE2
Kicker KX350.4
DC Audio 1.2k
Yep, stick with 3/4 thickness for wood.
Birch and MDF are the best for boxes in my opinion. They both have pros and cons though.
Birch plywood (11-13 layer) is lighter, stronger and produces way less saw dust. It is also easier to paint and doesn't split too bad when screwing into it. However it routs like crap, and it usually costs a bit more than MDF.
MDF is cheaper, easier to cut odd angles in, and way nicer to rout (roundovers and such.) However it is heavy, produces craploads of sawdust, is really easy to split when screwing into it, and if you get MDF wet, it is pretty much junk.
I don't have experience with any other types of wood though, sorry.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
  • Who's Online   0 Members, 0 Anonymous, 1257 Guests (See full list)
