- how much air space? trunk can be like 17 h 38 wide 24 d.
-mainly decaf music on these subs what do you think subs should be ported at?( not to low dont want the higher notes to sound like burps ) and it will be a slot port.
-should the subs have port in between the subs? or all the way to the right or left? ( so that they share or dont share air space? )
-its going to be wired to 1 ohm so 600 rms a piece daily 1200 peak. big 3 and 1/0 knu oxygen free wire will be used.
( just remember its a trunk build , the back seat is used daily and he listens to decafs it AQ subs and loudest this trunk sound is sub and port back )
no sealing the subs/box from trunk will not be considered place your opinions and advice i need it (:
Audioque has different series of subs what is the exact model of the subs.
Edited by Joe X
his trunk was the loudest with his old set up facing back your saying? if you change the box and or subs this might not be true anymore. I would guess you would want to tune to 32-35 as for box design its w/e you think is best no one can tell you one right way you might even want to consider port to the side as well
REP
I have heard AQs like 35-37hz tuning
http://www.stevemead...cherokee-build/
2005 Jeep Grand Cherokee
Alpine CDE-hd148bt
Alpine PKG-RSE2
PRV Audio (4) 6MB200 front/rear doors
PRV Audio (4) TW350Ti dash/rear doors
Kicker KX350.4
Obsidian Audio (1) 18 D4 v2
revamp (2) Stereo Integrity HT 18d2
DC Audio 1.2k
5.25ft^3 tuned @34hz
revamp Infinite Baffle Cpillar
AudioTechnix 60mil deadener
KnuKonceptz & SkyHigh wire (complete setup)
sd2.5 as they can see 600rms 1200 peak a 1200.1 will be on both,
why port to side? and these are recommendations i dont think port and sub placement would change volume much but its the only way they can be fired anyways i asked hz on decaf from everyone personal experience.
4.25 - 4.5net, 35hz tuning, 16^2 port area
be more elaborate on this of reasons why
my aq loves alot of air and 35hz.
  • Who's Online   0 Members, 0 Anonymous, 6960 Guests (See full list)
