Slot Port for 2 DD 3515
SlamminBeats
Does anyone think i could do a slot port design for these with these dimensions?
Will be on 2k for the time being. Daily use.
22h 32 w 27 d
if u must you can add to the height a bit. No too much though
someone on here can design you a box for those subs!!
REP
I tried to do something on you dims but yor Vb (net internal volume) is too low for those subs, minimum needs to be 4 cu.ft. per sub 6.6 for two subs is just not enough.
Enclosure Specifications:
Fb = 35,331 Hz
Vb = 6,636 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 17 in
External Width = 36 in
External Depth = 28 in
Number of Ports = 2
Aero Port Diameter = 6
Aero Port Length = 14
Fb = 35,331 Hz
Vb = 6,636 ft^3
Number of Ports = 2
agreed. box will need to be bigger by the time you figure all the displacement, will work but wont be ideal for the subs. 2 12s would have worked better or 1 18 in with that much volume.
The DD box has proven to be very effective iwth this. They love port so you may want to be in the 17-18-19 per cube range too.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i realize my space is limited but i already have these, and i will be getting a crossover or SUV eventually, so they will have plenty of room by then.
SO with that being said. Are their any slot port configurations that will work??
is that all the space you have? if so I cant see it happening. you could run them sealed. could possibly invert them as they chew up space pretty quick like that. or even external aeros but if it has to be confined in that space i cant see it.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
So like would they not be loud or something if they only had 3.3 cubes each?
I assume they would still be loud, but just not to their potential right?
maybe i should have gotten the 2500s...=/
