Slot Port for 2 DD 3515
SlamminBeats
they will be loud but it will be tough to get them to potential. You'll be choking them in a box thats too small wtih too little port. it will effect low end and with the small port could also induce noise. it will increase power handling but will decrease its ability to disburse heat.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
but if its all i can work with for now, im gonna go with it. I'm assuming it will be louder than my current setup, since the box for my RE's is awful and has no port area at all.
hmmm well i def want 2 subs to max my cone area.
will be somewhat negated in too small of box. 18 would come to life in same size enclosure.
i realized that but, i would be losing so much cone area it wouldnt be worth it. I have never liked my single sub set ups. Never loud compared to my 2 15 set ups i have stuck with. Also what should i tune them to?
i also may be adding another amp to this current set up. that would help, it would be on 4k instead of 2k then.
If you can manage to fit the aero ports external then something could be worked out.
impossible, theres no more space.
do one of those on 2k in about 3.75 cubes with a single 8 inch aero and watch it be louder than both of your REs
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
think im gonna go with what i can work with. It will be louder than my old set up and thats all i care about. Ill have these subs for a long time and when i get a bigger vehicle and more power, they will be even better.
