Come on dude. I've pretty much given you step by step instruction.
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
just nervous, my first box, i wanna make it good :)
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
2 15s 4inch coil psi recones temp til my subs are reconed
Focal P165-v15
Audison voce quattro
fully active
Only gonna get louder
146.1 at 38hz
138.x at 24hz
Build log
http://www.stevemeadedesigns.com/board/topic/191444-mazda-3-sedan-sql-build-audisonfocalb2aa/
I understand completely. But nothing is better than personal experience. If I were local to you to help you, I would. But the best thing for you to possibly do is just go for it. You've already been given advice. Now just go get her built. :clapping:
under construction
u hate c-fizzy?
ok thanks guys, got it all pre fitted and hopefully start drilling and glueing soon, just gotta make sure i got some screws, ill get a picture up in a few
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
i did give step by step directions lmao.
i understand i did my first box with no help. if you know some one that has wood working experience i suggest you ask them for help.
as for screws it depends on the thickness of the wood. for 3/4" wood i would use atleast 1 1/2" long wood screws i prefer 2". test fit the pre drill. take a peice of scrape wood and drill a hole with a slightly smaller drill bit then the screw. then put the screw in the test hole. if it goes it nice and snug its good. if you have to realy work it in might want to try a drill bit bigger. if it goes in real easy the hole is to big.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
yoo, so where working on it, we have split the wood like 4 times, will this effect the sound quality or should i just fill it with glue?? thanks!
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
What size do you recommend for screws and pre drilling bit size?, should i make the middle part first and then pre drill the bottom after i glue all the middle together
Use MDF screws.
You may like this:
http://www.norbord.com/images/screws-MDF.pdf
no idea there was mdf screws.... will the cracks really matter?? like will it make a diffrence :(
2007 Mazda 3 Sedan
Pioneer 80-prs
B2 Zero.7
Focal P165-v15
fully active
146.1 at 38hz
138.x at 24hz
Build log
  • Who's Online   2 Members, 0 Anonymous, 8951 Guests (See full list)
